  • New Member
  • Member For: 2y
Posted
Hi, I've got a 2009 g6e turbo and am having issues with the dual zone climate control.
Both sides works fine when on cold setting but when I try and put heaters on only the driver side works. The passenger side keeps blowing cold air. I tried putting a new airmix shaft in but it still didn't fix the problem.
Any help will be greatly appreciated.
  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 3m 2d
Posted
:Welcome2FordXR6t:
sounds like the HIM is faulty... hard to say for sure, but it's likely an electronic issue if you're replaced the mixer shaft...
  • Site Developer
Posted
did the HIM get coded at all to match the car?
check the plumbing for the vents/hoses and make sure there's not a diversion of air happening relative to those vents and the cold/hot system.
  • New Member
  • Member For: 2y
Posted
Didnt know it needed to be coded. It's every vent, floor,face etc on the passenger side that stay cold so that's why I thought it had to be the flap controlled by airmix shaft on that side couldn't be working which is why I replaced shaft. Maybe the shutter itself is broken? I just didn't want to have to take dash right out to check it
  • Site Developer
Posted
I honestly can't remember if it needs to be coded to the car... probably not... but yeah, I'd imagine checking the hardware like shutters etc is your next port of call.
