Lennox Member 2,586 Member For: 13y 5m 24d Gender: Male Location: Perth Posted 22/10/14 03:32 AM Posted 22/10/14 03:32 AM (edited) I'll just grab a 5L unless its like $150 bucks or somethingunless a few of us wanna split a 20L? Edited 22/10/14 03:33 AM by Lennox
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Legacy Donating Member 2,697 Member For: 15y 9m 29d Gender: Male Location: Work Posted 22/10/14 04:08 AM Posted 22/10/14 04:08 AM put me down for 20L of the diff oil. will distribute it from there.those who want, bring a 2L jug and some cash 2
Lennox Member 2,586 Member For: 13y 5m 24d Gender: Male Location: Perth Posted 22/10/14 04:41 AM Posted 22/10/14 04:41 AM I'll grab 4l or something off yamate when we get it 1
discostig Manual mode ________________________ All day, erryday Legacy Donating Member 13,798 Member For: 18y 8m 26d Gender: Male Location: Probably above atmospheric pressure Posted 22/10/14 10:50 AM Posted 22/10/14 10:50 AM (edited) Just checked the GW site and for the diff oil for an FPV F6 either BFII or FG it notes needing the additive which I've read about before and have heard is expensive:DifferentialULTRA CLEAR SYN 85w140Service Refill Capacity: 1.82 Litres (see note 463) NOTES 463 Add 40 ml. of additive Ford Part No. R178, at each oil change. Refer to Dealer. Castrol I have previously read people using SAF-XA which I think needs no additive. The Castrol site picker (they both actually use the same datateck site) for either an FPV F6 BFII or FG says use the below oil with NO ADDITIVE: DIFFERENTIAL CASTROL SYNTRAX 80W-140Full synthetic rear axle fluid incorporating Castrol's most advanced transmission fluid technology. Engineered to provide protection at the extremes of high and low operating temperatures, it is our prime recommendation for rear axles used in competition, severe duty and long drain applications. Suitable for both limited and non-limited slip rear axles. SAE 80W-140, API GL5/6.Service Refill Capacity: 1.82 Litres.See note 706 below. 706Do NOT use any additives. Thoughts from those in the know? Edited 22/10/14 10:55 AM by -Stever-
Boganspeed Will do skids for food Legacy Donating Member 1,177 Member For: 14y 9m 15d Gender: Male Location: Perth SOR Posted 22/10/14 12:34 PM Posted 22/10/14 12:34 PM So then we'd just need another maintenance day to do all the changes.First step, find out when Kyle is not in town and book it on that date..... 5
masda74 To Loud Legacy Donating Member 4,114 Member For: 14y 8m 20d Gender: Male Location: WA, Perth Posted 22/10/14 12:46 PM Posted 22/10/14 12:46 PM (edited) Hahahaha Gold.But he will be supplying the oil. Is that a wise choice?Welcome back Phill. Where have you been lately? Edited 22/10/14 12:46 PM by masda74
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 10m 27d Gender: Male Location: Perth Posted 22/10/14 12:51 PM Posted 22/10/14 12:51 PM A little birdy tellls me any of the next 5 weekends will be Ideal for excluding Kyle 1
GeGe6 Legacy Donating Member 1,980 Member For: 14y 1m 12d Gender: Male Location: Perth, SOR Posted 23/10/14 12:58 AM Posted 23/10/14 12:58 AM Just gauging interest form anyone else on purchase of catch can.Have found an eBay sell with the below catch can.They are split camber and baffled with drain plug.This OIL CATCH CAN Spiltflow system is designed to clean and seperate oil residues from the engine crankcase. The oil residue are seperated and filtered as it passes through the baffled can allowing clean air back in the inlet system of your vehicle. A simple application that is easy to fit for results on perfromance vehicles. The unit can be pulled apart for easy cleaning and also has a draining plug.Is any one else interested in purchase?(Any question on unit ask Arron, as he runs two of this type). Lol thanks Arron.I have had a quick chat to supplier on discount a little while ago and he could do two units for $85.00 this needs confirming again.If a few are keen I will hit him up for further discount.Cheers
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 10m 27d Gender: Male Location: Perth Posted 23/10/14 01:00 AM Posted 23/10/14 01:00 AM Keen, depending on how hard he can squeeze his price I might take 2.
GeGe6 Legacy Donating Member 1,980 Member For: 14y 1m 12d Gender: Male Location: Perth, SOR Posted 23/10/14 01:23 AM Posted 23/10/14 01:23 AM That's my thinking also.
