Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Legacy Donating Member 2,697 Member For: 15y 9m 24d Gender: Male Location: Work Posted 23/05/16 11:07 AM Posted 23/05/16 11:07 AM So really, what your saying is there is no way around it.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 10m 22d Gender: Male Location: Perth Posted 23/05/16 11:28 AM Posted 23/05/16 11:28 AM E10 with a high flow cat is a better option for passing emissions.
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Legacy Donating Member 2,697 Member For: 15y 9m 24d Gender: Male Location: Work Posted 23/05/16 11:31 AM Posted 23/05/16 11:31 AM So, if someone was to get pulled over and put over the pits, including emissions, you could throw a tank of E10 and re-tune/de-tune it to pass?
k31th less WHY; more WOT Site Developer 30,020 Member For: 18y 4m 4d Gender: Male Location: Melbourne Posted 23/05/16 11:36 AM Posted 23/05/16 11:36 AM Which emissions test... Not all emissions tests are made equal...?
turbotrana Member 2,586 Member For: 23y 4m 15d Gender: Male Posted 23/05/16 11:57 AM Posted 23/05/16 11:57 AM Remember the ring in the front pipe of the exhaust of FGs put there to heat the catalitic converter up quicker. So it would be hard to pass the cold start emissions test which the car manufacturers need to comply with. Pretty sure emission testing stations are all hot start tests so a good injector like ID1000 and twin factory cats would pass if tuned correctly. It would need the injectors to be dialed in really well so that all the closed loop trimmings work properly. E85 should make it easier to pass. In the US they do dump a bit of ethanol in the tank to pass the test. A very important factor is having hot cats just before the testing.
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 10m 22d Gender: Male Location: Perth Posted 23/05/16 12:04 PM Posted 23/05/16 12:04 PM 28 minutes ago, k31th said: Which emissions test... Not all emissions tests are made equal...? IM240
k31th less WHY; more WOT Site Developer 30,020 Member For: 18y 4m 4d Gender: Male Location: Melbourne Posted 23/05/16 12:29 PM Posted 23/05/16 12:29 PM Yep, with IM240, if you can get a tuner to 5 gas test it and tune it to pass that, it should pass the IM240 on 98 alone... but a little ethanol in the tank would help. If you tried to use E85 the tester would be able to smell the difference and may strike it as a failure automatically due to trying to "cheat the system" with a different fuel.
PhilMeUp Member 1,045 Member For: 18y 29d Gender: Male Location: Perth, Western Australia Posted 23/05/16 05:13 PM Posted 23/05/16 05:13 PM (edited) 5 hours ago, Krazy Kyle said: So, if someone was to get pulled over and put over the pits, including emissions, you could throw a tank of E10 and re-tune/de-tune it to pass? What I got told (from asking lots of people): - Put an original Ford cat on. Apparently it's one of the rare times when the factory has the best item. - Car might pass with factory cat on. If not then put car on dyno and rev the hell of it. Get cat as hot as possible - they work better when they're hot. - If it still fails... dunno... time for HP Tuners. My green Tornado has been passed, but I haven't picked it up yet. I'll find out some info about it tomorrow. Wasn't cheap ($580) and the car was there for three weeks. XFT quoted me $1,500 to pass an emissions test. Edited 23/05/16 05:15 PM by PhilMeUp
Ralph Wiggum Moar Powar Babeh Legacy Donating Member 19,334 Member For: 20y 10m 22d Gender: Male Location: Perth Posted 23/05/16 09:28 PM Posted 23/05/16 09:28 PM 9 hours ago, Krazy Kyle said: So, if someone was to get pulled over and put over the pits, including emissions, you could throw a tank of E10 and re-tune/de-tune it to pass? In the simplest of terms yes.
MattyP MattyP Legacy Donating Member 6,317 Member For: 14y 3m 10d Gender: Male Location: Central Coast Posted 23/05/16 10:58 PM Posted 23/05/16 10:58 PM What are the parameters for the emissions test? Is it wot or cruise/idle Also Do we get hydrous ethanol at all?
