discostig Manual mode ________________________ All day, erryday Legacy Donating Member 13,798 Member For: 18y 9m 2d Gender: Male Location: Probably above atmospheric pressure Posted 22/09/12 01:51 PM Posted 22/09/12 01:51 PM Yeah cool. Not sure how much vacuum the intake would really produce anyway.
PSI O6T Legacy Donating Member 440 Member For: 13y 11m 13d Gender: Male Location: sydney Posted 22/09/12 07:39 PM Author Posted 22/09/12 07:39 PM yeh is got metal spiral all the way through it,no brobs there, its 100mm and forms a nice oval shape under the headlight, it should be getting sh*t loads of air now.
Kroozin Menace Legacy Donating Member 1,990 Member For: 15y 4m 5d Gender: Male Location: Sydney Posted 22/09/12 08:24 PM Posted 22/09/12 08:24 PM Just watch the ducting tube doesn't deattach from the spiral as it gets older..
Wenier Legacy Donating Member 1,736 Member For: 16y 7m 8d Gender: Male Location: Christchurch, New Zealand Posted 23/09/12 01:56 AM Posted 23/09/12 01:56 AM The filter will catch it though.
PSI O6T Legacy Donating Member 440 Member For: 13y 11m 13d Gender: Male Location: sydney Posted 23/09/12 02:53 AM Author Posted 23/09/12 02:53 AM ill see how it goes,it looks a bit cheap, I might go the f6 route later ,looks better imo. but as far as effectiveness goes it works a treat.....
Panda Eyes flame magnet Legacy Donating Member 5,674 Member For: 18y 3m 10d Gender: Male Location: adelaide hills- 'race air' central Posted 24/09/12 10:22 PM Posted 24/09/12 10:22 PM just a whopping hole in the front of the box (lower half so its under the filter) is fine. I had mine like that until I got the aftermarket cooler n stuff....plus you can have the hole much bigger than you have, you cant see it cause its hidden and it gives an awesome flutter too....
PSI O6T Legacy Donating Member 440 Member For: 13y 11m 13d Gender: Male Location: sydney Posted 25/09/12 02:18 AM Author Posted 25/09/12 02:18 AM question; when running the cold side piping for the aftermarket intercoolers what happens to the airbox? where does it get air from , turbo inlet ?sorry for the noob questions
Ciaran Thooperrrrrrr Legacy Donating Member 2,768 Member For: 15y 1m 24d Gender: Male Location: NOR, Western Australia Posted 25/09/12 02:28 AM Posted 25/09/12 02:28 AM Airbox usually replaced with a turbo side pod, going straight off the turbo itself
PSI O6T Legacy Donating Member 440 Member For: 13y 11m 13d Gender: Male Location: sydney Posted 25/09/12 02:39 AM Author Posted 25/09/12 02:39 AM ok that's what I was thinking,the pw cooler pipe cold side looks very long and wraps around front of engine, where the rapid systems look very short in comparison . could you use the rapid cold side piping on a pw cooler ?
Ciaran Thooperrrrrrr Legacy Donating Member 2,768 Member For: 15y 1m 24d Gender: Male Location: NOR, Western Australia Posted 25/09/12 02:46 AM Posted 25/09/12 02:46 AM As long as the dimensions on the coolers are the same I don't see why not.Might find it a bit hard to fit if they are offset too much, but nothing a bit of joiners the right size/shape couldn't fix!Someone will confirm though =]
