Posted
Two cannibals were eating a bloke,they started from opposite ends
one said to the other" how you going"
reply "Oh, just great,Im having a ball"
Posted
A missionary,priest, holy roller whatever,was riding his treadly past the cannibale part of the forest.Two cannibals were watching him and one turned to the other and said "Hm look,there goes meals on wheels"
Posted
A mobb of cannibals caught these two blokes,got two fires going,got two big pots full of water,one on each fire,stuck a bloke in each pot ready to boil them up.
Ten minuites later one of the blokes starts chuckling to him self,his mate says "whats so f***n funny"
The reply "I just pissed in the water"
  • Bored Member
  • Administrator
  • Member For: 23y 10m 9d
Posted
Murphy's laws of combat operations...
1. Friendly fire - isn't.
2. Recoilless rifles - aren't.
3. Suppressive fires - won't.
4. You are not Superman; Marines and fighter pilots take note.
5. A sucking chest wound is Nature's way of telling you to slow down.
6. If it's stupid but it works, it isn't stupid.
7. Try to look unimportant; the enemy may be low on ammo and not want to waste a bullet on you.
8. If at first you don't succeed, call in an air strike.
9. If you are forward of your position, your artillery will fall short.
10. Never share a foxhole with anyone braver than yourself.
11. Never go to bed with anyone crazier than yourself.
12. Never forget that your weapon was made by the lowest bidder.
13. If your attack is going really well, it's an ambush.
14. The enemy diversion you're ignoring is their main attack.
15. The enemy invariably attacks on two occasions: when they're ready; when you're not.
16. No OPLAN ever survives initial contact.
17. There is no such thing as a perfect plan.
18. Five second fuses always burn three seconds.
19. There is no such thing as an atheist in a foxhole.
20. A retreating enemy is probably just falling back and regrouping.
21. The important things are always simple; the simple are always hard.
22. The easy way is always mined.
23. Teamwork is essential; it gives the enemy other people to shoot at.
24. Don't look conspicuous; it draws fire. For this reason, it is not at all uncommon for aircraft carriers to be known as bomb magnets.
25. Never draw fire; it irritates everyone around you.
26. If you are short of everything but the enemy, you are in the combat zone.
27. When you have secured the area, make sure the enemy knows it too.
28. Incoming fire has the right of way.
29. No combat ready unit has ever passed inspection.
30. No inspection ready unit has ever passed combat.
31. If the enemy is within range, so are you.
32. The only thing more accurate than incoming enemy fire is incoming friendly fire.
33. Things which must be shipped together as a set, aren't.
34. Things that must work together, can't be carried to the field that way.
35. Radios will fail as soon as you need fire support. (Corollary: Radar tends to fail at night and in bad weather, and especially during both.)
36. Anything you do can get you killed, including nothing.
37. Make it too tough for the enemy to get in, and you won't be able to get out.
38. Tracers work both ways.
39. If you take more than your fair share of objectives, you will get more than your fair share of objectives to take.
40. When both sides are convinced they're about to lose, they're both right.
41. Professional soldiers are predictable; the world is full of dangerous amateurs.
43. Military Intelligence is a contradiction.
44. Fortify your front; you'll get your rear shot up.
46. Weather ain't neutral.
47. If you can't remember, the Claymore is pointed towards you.
48. Air defence motto: shoot 'em down; sort 'em out on the ground.
49. 'Flies high, it dies; low and slow, it'll go.
50. The Cavalry doesn't always come to the rescue.
51. Napalm is an area support weapon.
52. Mines are equal opportunity weapons.
53. B-52s are the ultimate close support weapon.
54. Sniper's motto: reach out and touch someone.
55. Killing for peace is like screwing for virginity.
56. The one item you need is always in short supply.
57. Interchangeable parts aren't.
58. It's not the one with your name on it; it's the one addressed "to whom it may concern" you've got to think about.
59. When in doubt, empty your magazine.
60. The side with the simplest uniforms wins.
61. Combat will occur on the ground between two adjoining maps.
62. If the Platoon Sergeant can see you, so can the enemy.
63. Never stand when you can sit, never sit when you can lie down, never stay awake when you can sleep.
64. The most dangerous thing in the world is a Second Lieutenant with a map and a compass.
65. Exceptions prove the rule, and destroy the battle plan.
66. Everything always works in your HQ, everything always fails in the Colonel's HQ.
67. The enemy never watches until you make a mistake.
68. One enemy soldier is never enough, but two is entirely too many.
69. A clean (and dry) set of BDU's is a magnet for mud and rain.
70. The worse the weather, the more you are required to be out in it.
71. Whenever you have plenty of ammo, you never miss. Whenever you are low on ammo, you can't hit the broad side of a barn.
71. The more a weapon costs, the farther you will have to send it away to be repaired.
72. The complexity of a weapon is inversely proportional to the IQ of the weapon's operator.
73. Field experience is something you don't get until just after y u need it.
74. No matter which way you have to march, its always uphill.
75. If enough data is collected, a board of inquiry can prove anything.
76. For every action, there is an equal and opposite criticism. (in boot camp)
77. Air strikes always overshoot the target, artillery always falls short.
78. When reviewing the radio frequencies that you just wrote down, the most important ones are always illegible.
79. Those who hesitate under fire usually do not end up KIA or WIA.
80. The tough part about being an officer is that the troops don't know what they want, but they know for certain what they don't want.
81. To steal information from a person is called plagiarism. To steal information from the enemy is called gathering intelligence.
82. The weapon that usually jams when you need it the most is the M60.
83. The perfect officer for the job will transfer in the day after that billet is filled by someone else.
84. When you have sufficient supplies ammo, the enemy takes 2 weeks to attack. When you are low on supplies ammo the enemy decides to attack that night.
85. The newest and least experienced soldier will usually win the Medal of Honour.
86. A Purple Heart just proves that were you smart enough to think of a plan, stupid enough to try it, and lucky enough to survive.
87. Murphy was a grunt.
88. Beer Math --> 2 beers times 37 men equals 49 cases.
89. Body count Math --> 3 guerrillas plus 1 probable plus 2 pigs equals 37 enemies killed in action.
90. The bursting radius of a hand grenade is always one foot greater than your jumping range.
91. All-weather close air support doesn't work in bad weather.
92. The combat worth of a unit is inversely proportional to the smartness of its outfit and appearance.
93. The crucial round is a dud.
94. Every command which can be misunderstood, will be.
95. There is no such place as a convenient foxhole.
96. Don't ever be the first, don't ever be the last and don't ever volunteer to do anything.
97. If your positions are firmly set and you are prepared to take the enemy assault on, he will bypass you.
98. If your ambush is properly set, the enemy won't walk into it.
99. If your flank march is going well, the enemy expects you to outflank him.
100. Density of fire increases proportionally to the curiousness of the target.
101. Odd objects attract fire - never lurk behind one.
102. The more stupid the leader is, the more important missions he is ordered to carry out.
103. The self-importance of a superior is inversely proportional to his position in the hierarchy (as is his deviousness and mischievousness).
104. There is always a way, and it usually doesn't work.
105. Success occurs when no one is looking, failure occurs when the General is watching.
106. The enemy never monitors your radio frequency until you broadcast on an unsecured channel.
107. Whenever you drop your equipment in a fire-fight, your ammo and grenades always fall the farthest away, and your canteen always lands at your feet.
108. As soon as you are served hot chow in the field, it rains.
109. Never tell the Platoon Sergeant you have nothing to do.
110. The seriousness of a wound (in a fire-fight) is inversely proportional to the distance to any form of cover.
111. Walking point = sniper bait.
112. Your bivouac for the night is the spot where you got tired of marching that day.
113. If only one solution can be found for a field problem, then it is usually a stupid solution.
  • Gandalf the Grey, Maiar of Manwë and Varda, Team HgAg/Sneaky
  • Member For: 23y 2m 24d
Posted
hazardous label
:lol: :birthdaywish:
:beerchug:
  • I see red
  • Member For: 23y 9m 6d
Posted
She spent the first day packing her belongings into boxes, crates and suitcases.
On the second day, she had the movers come and collect her things.
On the third day, she sat down for the last time at their beautiful dining room table by candlelight, put on some soft background music, and feasted on a pound of shrimp, a jar of caviar, and a bottle of Chardonnay.
When she had finished, she went into each and every room and deposited a few half-eaten shrimp shells, dipped in caviar, into the hollow of the curtain rods. She then cleaned up the kitchen and left.
When the husband returned with his new girlfriend, all was bliss for the first few days. Then slowly, the house began to smell. They tried everything; cleaning and mopping and airing the place out. Vents were checked for dead rodents, and carpets were steam cleaned. Air fresheners were hung everywhere.
Exterminators were brought in to set off gas canisters, during which they had to move out for a few days, and in the end they even paid to replace the expensive wool carpeting.
Nothing worked. People stopped coming over to visit... Repairmen refused to work in the house...The maid quit...
Finally, they could not take the stench any longer and decided to move.
A month later, even though they had cut their price in half, they could>not find a buyer for their stinky house. Word got out, and eventually, even the local Realtors refused to return their calls.
Finally, they had to borrow a huge sum of money from the bank to purchase a new place.
The ex-wife called the man, and asked how things were going. He told>her the saga of the rotting house. She listened politely, and said that she missed her old home terribly, and would be willing to reduce her divorce settlement in exchange for getting the house back...
Knowing his ex-wife had no idea how bad the smell was, he agreed on price that was about 1/10th of what the house had been worth...But only if she were to sign the papers that very day. She agreed, and within the hour, his lawyers delivered the paperwork.
A week later, the man and his new girlfriend stood smirking as they watched the moving company pack everything to take to their new home...
...including the curtain rods.
I LOVE A HAPPY ENDING, DON'T YOU????
  • In Your Face
  • Member For: 23y 6m 14d
Posted
A guy comes walking into a bar with a turtle in his hand.
The turtle's one eye is black and blue, two of his legs are bandaged, and his whole shell is taped together with duct tape.
The bartender looks at the guy and asks:
"What's wrong with your turtle?"
"Not a thing," the man responds, this beat up turtle is faster than your dog!"
"Not a chance!", replies the barkeep.
"Okay then, says the guy... you take your dog and let him stand at one end of the bar. Then go and stand at the other end of the room and call your dog. I'll bet you $500 that before your dog reaches you, my turtle will be there."
So the bartender, thinking it's an easy $500, agrees.
The bartender goes to the other side of the bar, and on the count of three calls his dog.
Suddenly the guy picks up his turtle and throws it across the room, narrowly missing the bartender, and smashing into the wall and says -
"I WIN... Told you it'll be there before your dog!"
  • In Your Face
Posted
A man walked into a pub with an Ostrich and a *beep* Cat. He walked up the the bar and said "Beer for me, beer for the ostrich, whisky for the cat". They found a table, sat down and drank their drinks.
Next it was the ostrichs round. He walked up to the bar and said "Beer for me, beer for the man, whisky for the cat". He took the drinks back to the table and they drank them.
When it was the Cat's turn to buy, he told them to "F@@k off!"
So the man went back to the bar and said "Beer for me, beer for the ostrich and whisky for the cat".
The Barman was curious about this and said "I notice that you and the ostrich have both bought a round but the cat hasn't. Why is this?".
The man replied, "I helped a little old lady across the road, and she turned out to be my Fairy Godmother. She granted me one wish".
"What did you wish for?" said the Barman.
"I wished for a long legged bird with a tight *beep*!"
  • In Your Face
Posted
An elderly couple was on a cruise and it was really stormy.
They were standing on the back of the boat watching the moon, when a wave came up and washed the old woman overboard.
They searched for days and couldn't find her. So the captain sent the old man home with the promise that he would notify him as soon as they found something.
Three weeks went by and finally the old man got a fax from the ship.
It read: "Sir, sorry to inform you, we found your wife had died in the ocean. We hauled her up to the deck, and found an oyster attached to her butt. Inside it was a pearl worth $50,000.
Please advise?"
The old man faxed back: Send me the pearl and re-bait the trap!
