  • less WHY; more WOT
  • Site Developer
  • Member For: 18y 4m 3d
Posted
My technique with tiny wires is to double or triple length strip the wire back and fold it up until it's as thick as a standard gauge wire for the red crimp - ratchet crimped and all done.
  • Moar Powar Babeh
  • Legacy Donating Member
  • Member For: 20y 10m 20d
Posted
If only I'd thought of that.
You may notice the other two don't have a filler wire? They are double crimped as was the earth. Filler wire is only temp until I get some non insulated crimps that I can double strip,crimp, solder and heat shrink.
The other end of the cable had a beautiful Mil spec cannon plug. What possessed them to use terminal posts on the end that is exposed to the elements is beyond me.
  • Site Developer
Posted
post may contain sarcasm?
  • ...JD TUNING ADELAIDE...
  • Member For: 18y 2m 13d
Posted
#electricalskillzofamonkey
Finally got luke on something that's almost nothing but we will take it
  • Moar Powar Babeh
Posted
I was all out of cumbersome household connectors so I had to make do.
Posted
Now that's f*ckn funny
10a outlet for switching .....
  • Dropping a turd
  • Member For: 18y 9m 17d
Posted
What is the sensor for Luke, pressure/temp???
  • Moar Powar Babeh
Posted
It's the pump control signal from the fuel reg. Middle wire suppliers a frequency produced by the pressure transducer in the reg. The pump speed changes base upon this signal.
  • Dropping a turd
Posted
Ah..So its not running at full pressure at idle. Does it just reduce the voltage , thus reduce the current draw and speed.
  • Moar Powar Babeh
Posted
The motor in the pump is an AC brushless motor. The unit has an inverter/speed controller built in an the centre pin on the pump is the speed control input.
Based on return flow and rail pressure the pump out pump can be reduced down to 20pc at low loads. End result is quiet pump, less heat into the fuel and reduced electrical load at idle.
